1998 Ford Expedition Rear Heater works front does not
LEXICAIRO
  • 1998 FORD EXPEDITION
  • V8
  • 4WD
  • 55,365 MILES
Anyone know the issue here? I checked the control. The heat knob has been replaced and is not cracked. Any advice is appreciated!
Saturday, December 13th, 2008 AT 3:51 PM
BMRFIXIT
  • 19,053 POSTS
Is it the blower and no air at all
or no hot air
Sunday, December 14th, 2008 AT 7:28 AM
LEXICAIRO
Thanks MRFIXIT for responding. It is not the blower it is working fine. Just no heat in the front!
Tuesday, December 16th, 2008 AT 12:20 PM
BMRFIXIT
  • 19,053 POSTS
So its blowing cold air no mater what temp setting u have on
suspect blend door actuator
which is very common
also you may wont to check the heater core hoses under hood if both hot and they should
if not or on hot and the other not than heater core need to be flushed
Tuesday, December 16th, 2008 AT 8:30 PM
LEXICAIRO
How difficult is replaciing the Blend Actuator?
Wednesday, December 17th, 2008 AT 6:44 AM
