HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Expedition
Engine
Symptoms
Coolant In Oil
SPONSORED LINKS
1998 Ford Expedition
SMOKEYBOUND
MEMBER
1998 FORD EXPEDITION
V8
4WD
AUTOMATIC
133,000 MILES
How can you tell if there is water in the oil? How can you fix it?
Wednesday, January 6th, 2010 AT 7:42 AM
MECHANIC
Check the oil. If coolant is mixed, chances are it will be a creamy brown color. Also, check under the filler cap.
If you have coolant mixing, let me know.
SPONSORED LINKS
Thursday, January 7th, 2010 AT 1:32 PM
SMOKEYBOUND
MEMBER
Yes it is creamy looking under the filler cap, but the oil is not creamy looking. What can I do to prevent anything from going bad?
Thursday, January 7th, 2010 AT 7:03 PM
Please
login
or
register
to post a reply.
Related Engine Coolant In Oil Content
2004 Ford Expedition Water In Oil
I Had An Oil Change And They Said I Have Water In My Oil What Could Be The Cause For That And Can It Be Fix.
Asked by
coreyhines34
1 ANSWER
2004
FORD EXPEDITION
VIDEO
Can You Fix a Head Gasket with a Sealer?
Instructional repair video
GUIDE
Coolant Mixing With Engine Oil
Coolant mixing with engine oil is a sign of a serious problem, often caused by a blown head gasket, or a failed engine oil cooler. When these components fail, they allow...
2004 Ford Expedition Coolant In The Oil
Hey Guys. I Sure Could Use Some Help. I Noticed My Expedition Had Began To Lose Coolant 2 Weeks Ago. I Looked At All The Hoses And Felt...
Asked by
uaengineering5
2004
FORD EXPEDITION
Engine Will Not Crank
It Wont Crank, No Sound Or Nothing. Check Starter, Starter Relay, Solenoid And Ignition Switch. I Tried To Jump The Solenoid, Nothing.
Asked by
kddavis1
1998
FORD EXPEDITION
Vehicle Will Not Start
Electrical Problem 1998 Ford Expedition V8 Four Wheel Drive Automatic He Battery And Alternator Were Both Replaced About 3 Months Ago...
Asked by
jag925
1998
FORD EXPEDITION
Will Not Start
I Have No Chipped In Key, The Theft System, Kicked In. I Tried All Tricks Google Said, Need Help. Please Someone Help.
Asked by
Gabriel Gutierrez
1 ANSWER
1998
FORD EXPEDITION
VIEW MORE
SPONSORED LINKS
Cylinder Head Gasket Blown Symptoms
Cylinder Head Installation
Online car repair manuals
