1997 Ford Expedition Spark plug/coil
165,000 MILES • V8 • 4WD • AUTOMATIC
JENG1029
I have a 97 Expedition, and the #3 spark plug has fouled. The problem is that the rubber piece on the bottom of the coil is broken off. Is this fixable? I have had a couple of people try to remove it, with no luck. I need to replace the catalytic converter, but don't want to spend the money if the plug/coil is not repairable. Thanks, Jenn
May 11, 2009 at 6:05 AM
  • 110,248 POSTS
Jenn,
Are you refering to the rubber boot that goes over the spark plug? If so, yes they are replaceable.
May 14, 2009 at 5:43 AM
JENG1029
It is the boot, however the boot is broken off. There is about an inch or two (I'm guessing because I cannot really see it that well) of the boot left attached to the plug. I cannot get that piece off/out.
May 14, 2009 at 6:27 AM
  • 110,248 POSTS
Are you able to get an knife in there to cut out the old boot? If cut at least enough to remove the spark plug?
May 15, 2009 at 3:01 AM
JENG1029
We have cut it to try to get a grip on it better, but are still unable to get it. Cannot get past it to the plug.
May 15, 2009 at 6:59 AM
  • 110,248 POSTS
You will need to get a long pair of needle nose plyers that can reach down in to get a bit one it and try to rip it off.
May 15, 2009 at 3:19 PM
JENG1029
Ok, I will give a shot. Thanks for your help. Wish me luck. lol
May 16, 2009 at 4:11 AM
