1997 Ford Expedition
CARTRELLB
  • 1997 FORD EXPEDITION
1997 Ford Expedition V8 Four Wheel Drive
Where is the brake light switch located and how can you tell if it is bad and how hard is it to replace
Friday, November 27th, 2009 AT 10:18 AM
  • 109,885 POSTS
It is at the top of the brake pedal. Chances are it is out of adjustment. If it needs replaced, just unplug the electrical plug and disconnect the switch. If you want to check the switch, there should be power to it at all times. When the circuit is closed in the switch, you should have power going through the switch. If nothing comes out, the switch is bad.
Thursday, December 3rd, 2009 AT 8:54 PM
