Torque converter
KBRO
1997 Ford Escort 2.0 Automatic Trans
Were do I find the drain plug if there is one for the Torque converter. I did the fluid and filter svc but whould like to drain converter.
Send me address to donate I will send something thru usmail
thanks
Nov 11, 2007 at 8:00 AM
  • 75,988 POSTS
I don't think it has drain plug. But if you really want to get rid of the dirty fluid-This what I do-I remove the transmission inlet pipe at the radiator stick it in a drain pan with hose then fire it up while I fill it with new fluid at the same time till it clears up.
HTH-Please send it and I'll be waiting for it-we need help
Address:
2Carpros.com INC.
341 W. Whittier Blvd
La habra, CA. 90631
Nov 11, 2007 at 8:40 AM
