I have a stuck seat belt in the back left seat of my 1998 4dr ford escort. How do i go about fixing it?
Thanks!
Thanks!
Jul 30, 2007 at 9:57 AM
Open the trunk and remove the top left gray lining behind the left rear seat by pulling the center of each of the two black plastic fasteners, then the fasteners themselves. Pull the C-shaped flat metal piece (about 1 by 2 inches, with white plastic on the bottom) out of the teeth above and below the seat belt mechanism to free the belt.
The owner of a 1998 Ford Escort four-door asked how to free a stuck seat belt in the back left seat. An expert explained how to access the retractor through the trunk lining and remove the C-shaped metal piece blocking the mechanism teeth so the belt can loosen.
