1994 Ford Escort Automatic Seatbelt Stuck
MISSDEADLOCKS1018
i just got a hand-me down for a much needed vehicle. A 94 escort. My brother had it prior to me getting it, the seatbelt (automatic) was stuck foward and the motor or something wouldnt let it go back. So he took it upon himself to rip the cables out or something to manually push the seatbelt back so he wouldnt get pulled over. I dont think it will pass inspection now, because its not working. How can i fix this problem?
Feb 22, 2006 at 12:01 PM
LOVESCARS
  • 359 POSTS
find a used unit at a salvage yard...good luck everything may need to be replaced new unless you can rig it manually
Feb 22, 2006 at 12:11 PM
Suggested Repair
Source a used automatic seatbelt assembly from a salvage yard. The motor, cables, and related parts that were damaged or removed may all need to be replaced with used or new components so the belt works for inspection. A manual setup was mentioned only as a possible last resort and may not pass inspection.
Conversation Summary
The owner of a 1994 Ford Escort has an automatic seatbelt that was stuck forward. A previous owner removed the cables so the belt could be pushed back by hand, and it no longer works, raising inspection concerns. The expert suggested finding a used unit at a salvage yard and said the related parts may need to be replaced new unless a manual setup can be arranged.
