1998 Ford Escort Hard Start Rough Idle
BRWNISHGLDCOLR
I have a 1998 Ford Escort LX. It has 86,000 miles on it. It is a 2WD stick shift. It has 4 cylinders. A few months ago, the problem started. Every time I try to start my car, it will crank but it will not start until I have turned it over 2 or 3 times. After it starts, the idle is very rough and will sometimes die, and I'll have to start it again. After I start driving it is fine, and the idle is even fine at stop lights. I don't know what I should do? Also, I have noticed a sputtering sound when I accelerate. What could this be? Are these things that I could fix, or will I need to take it in? We just moved to a new city, and we're short on money. I'd like to do as much as I can on my own. Any help would be greatly appreciated!
Aug 12, 2007 at 4:49 PM
  • 75,988 POSTS
[quote:64b5e12def="brwnishgldcolr"]I have a 1998 Ford Escort LX. It has 86,000 miles on it. It is a 2WD stick shift. It has 4 cylinders. A few months ago, the problem started. Every time I try to start my car, it will crank but it will not start until I have turned it over 2 or 3 times. After it starts, the idle is very rough and will sometimes die, and I'll have to start it again. After I start driving it is fine, and the idle is even fine at stop lights. I don't know what I should do? Also, I have noticed a sputtering sound when I accelerate. What could this be? Are these things that I could fix, or will I need to take it in? We just moved to a new city, and we're short on money. I'd like to do as much as I can on my own. Any help would be greatly appreciated![/quote:64b5e12def]
It sure sounds like it needs to build pressure before it starts-recommend the fuel pressure be checked for a start-to check for problems with the pump/pressure regulator/filter/ check valve etc.
Aug 12, 2007 at 8:58 PM
Suggested Repair
Check fuel pressure before starting to look for a weak fuel pump, pressure regulator, fuel filter, or check valve that is not holding pressure.
Conversation Summary
A 1998 Ford Escort LX cranks but often needs two or three attempts to start, then idles roughly and may stall until driven, after which it runs normally. It also sputters during acceleration. The expert says the system may need to build fuel pressure and recommends checking the pump, pressure regulator, filter, and check valve.
