1999 Ford Escort Jerking Takeoff
SLIMJIM40
i have a 1999 ford escort zx2
it has129000 thousand miles on it.
the engine size is a 2.1
i have a service engine light that keeps coming on and the engine jerks when i take off
i have had the speed sensor replaced twice and i still have the same problem the mechanic cant find the problem he said it maybe the transmision help...
Jul 8, 2007 at 4:47 AM
JWALTH02
  • 180 POSTS
Did you have that mechanic pull the codes for you? If not go to an autozone or checkers if available and have them pull them for free. Then let us know what they are.
Jul 8, 2007 at 6:16 AM
SLIMJIM40
yes they did a check and the code number was po715
Jul 8, 2007 at 9:58 AM
MERLIN2021
  • 17,250 POSTS
P0715 Turbine Shaft Speed Sensor Circuit
Might check wiring as well....
Jul 8, 2007 at 10:18 AM
Suggested Repair
With code P0715, inspect the turbine shaft speed sensor circuit wiring and connections. The speed sensor has already been replaced twice without fixing the jerking or service engine light.
Conversation Summary
The owner of a 1999 Ford Escort ZX2 reports a service engine light and jerking when taking off. The speed sensor was replaced twice, and a mechanic suggested the transmission might be at fault. A free code scan returned P0715, turbine shaft speed sensor circuit, and the expert advised checking the wiring as well.
