Running hot when idle
CHRGRFNDAN
  • FORD ESCORT
I have a '98 Ford Escort with 105,000 miles. When I'm driving everything is fine but when the weather is warm. If I'm idle for too long (stuck in traffic or catch a lot of red lights) the engine starts to run hot to the point where I'm afraid I'll overheat. Once I start driving again it cools back down. Is it the water pump, thermostat, radiator, or something else?
Monday, June 19th, 2006 AT 12:17 PM
TAURUSWHEEL
  • 718 POSTS
Is the fan kicking on as usual? Normal to heat up in hot weather and heavy traffic, unless the a c is on in which case the fan should also be on.
Monday, June 19th, 2006 AT 3:52 PM
CHRGRFNDAN
It may be the fan because before the temperature starts to rise the air coming from the A/C gets noticiably warmer.
Tuesday, June 20th, 2006 AT 7:38 AM
