1994 Ford Escort Radiator Fan Won't Come On
NIGERA17
i have a 94 ford escort wagon the radiator fan will not come on the fuses are good but when i take it off and wire it to battery it comes on i need to know what could be wrong or how to wire it to battery so it will cut off when car is turned off help
Sep 29, 2007 at 8:29 AM
BMRFIXIT
  • 19,053 POSTS
[quote:e7db1d5f10="nigera17"]i have a 94 ford escort wagon the radiator fan will not come on the fuses are good but when i take it off and wire it to battery it comes on i need to know what could be wrong or how to wire it to battery so it will cut off when car is turned off help[/quote:e7db1d5f10]
You can wire it throw an ignition source
But does the fuse has battery voltage it should if not check fusible links at the starter relay
Good luck
Sep 29, 2007 at 11:38 PM
Suggested Repair
Wire the radiator fan through an ignition-switched source so it shuts off with the key. First confirm the fan fuse has battery voltage; if it does not, check the fusible links at the starter relay.
Conversation Summary
The owner of a 1994 Ford Escort wagon says the radiator fan will not come on. The fuses appear good, and the fan runs when wired directly to the battery. The expert advises wiring it through an ignition source and checking whether the fuse has battery voltage, including the fusible links at the starter relay if it does not.
