Need to know an easy way to replace a thermostat on a 1.8 escort.
May 4, 2007 at 2:40 PM
Follow the upper radiator hose to the thermostat housing. On the 1.8, the thermostat is typically secured by two bolts and is not considered a difficult replacement.
The owner asked for an easy way to replace the thermostat on a 1998 Ford Escort 1.8 before seeing the car. The expert said to follow the upper radiator hose to the thermostat, which is held by two bolts, and that the job should not be tough.
