I have 550watt amp with 4 ouputs and a low and high pass filter. It is running a 1100 watt sub and 2- 240 watt 4-ways.
I go out to go to work 1 morning and its dead, jump it with my booster until I get to an auto parts store. They run a check on the battery, its dead and from 2003, and they check my alternator which is running 14.3 amps.
here's the thing. Will my alternator be able to put back what my amp is pulling or will it drain it til its dead? I believe it will. If so is there some type of affordable onboard battery charger that I can plug into my lighter that will put back more than it is pulling? Is there a dc/dc converter, thats affordable, that will pull less amps and transfer out enough amps to just hook it up between my battery and my asmplifier's power source?
poor man trying to stay rockin here fellas!
Sunday, February 11th, 2007 AT 4:13 PM
