1998 Ford Escort High Idle After Stop
DARKANGEL2000
Hi, Ford Escort 96,000 miles.
After starting and then moving off the engine continues to idle after foot is removed from the accelerator.
This happens especially when driving down the motorway so like having cruise control!!
1998 1.6i
Any thoughts
Thanks
Darren
Dec 12, 2006 at 5:43 AM
BRUCE HUNT
  • 3,754 POSTS
Very confusing what you have stated, but are you saying that the vehicle does not drop in engine speed when you let off the footfeed? If so, when the engine is off, try rotating the throttle cam and see if it moves freely. Then press the foot pedal and determine if the cable is sticking. If so, I would possibly try lube, but do a close examination and consider replacing the accelerator cable.
Dec 12, 2006 at 6:22 AM
DARKANGEL2000
It over idles for a while when you come to a stop and then drops back to normal. So when i stop for example at the end of the motorway, the engine is still revving whilst i'm stationary and then returns to normal after 10 secs say.
My concern is that i'm getting through fuel quickly and i drive a long journey every day as it is.
Thanks
Darren
Dec 12, 2006 at 8:10 AM
Suggested Repair
With the engine off, rotate the throttle cam to confirm it moves freely. Press the pedal and check whether the accelerator cable sticks. Lubricate if needed, inspect it closely, and replace the accelerator cable if it binds.
Conversation Summary
The owner of a 1998 Ford Escort 1.6i reported that the engine continues to idle high after the accelerator is released, especially after motorway driving, then returns to normal after about 10 seconds when stopped. Fuel use was a concern. The expert suggested checking that the throttle cam moves freely and that the accelerator cable is not sticking, then lubricating or replacing the cable if it binds.
