Ford Escort Overheating With AC Uphill
BENNYTOM24
Hi , I've a Ford Escort Desiel - Endura DE 1.8 - The car over heats while driving on AC & up hill , The car runs perfectly fine & does 140Kms per hr with not heating issue -
Radiatior / coolant anti freeze / Fan / Ac fan / Water Pump is checked & free from trouble .
Advise me on wat could be the issue
Regards
Benny
Sep 21, 2006 at 4:19 AM
NOS
  • 320 POSTS
change your thermostat(NOS) 8)
Sep 21, 2006 at 12:15 PM
BENNYTOM24
[quote:cc32821318="NOS"]change your thermostat(NOS) 8)[/quote:cc32821318]
Thermostat is changed & it works fine
Sep 22, 2006 at 3:31 AM
NOS
  • 320 POSTS
maybe a lower radiator hose sucking shut under heavy load like pulling a hill. AC always puts more load on engine have you washed the coolng fins out in front of condensor and reverse washed back through the radiator side. could be a slite leaking headgasket problem puting compression back in the cooling system (NOS) 8)
Sep 22, 2006 at 12:42 PM
BUBBA_KOSKI
  • 129 POSTS
head gasket, radiator partially plugged, hoses, and not enough flow
Sep 28, 2006 at 3:45 PM
Suggested Repair
After confirming the thermostat, check for a lower radiator hose collapsing under load, restricted radiator or condenser fins, poor coolant flow, and a possible slight head gasket leak pressurizing the cooling system.
Conversation Summary
The owner of a Ford Escort diesel reports overheating with the air conditioning on and when climbing hills, while highway driving is otherwise fine. The radiator, coolant, fans, and water pump were already checked. An expert suggested replacing the thermostat, and the owner said it was changed and works. Further advice pointed to a collapsing lower hose under load, restricted cooling fins, poor flow, or a slight head gasket leak.
