Overheating
BENNYTOM24
Hi , I've a Ford Escort Desiel - Endura DE 1.8 - The car over heats while driving on AC & up hill , The car runs perfectly fine & does 140Kms per hr with not heating issue -
Radiatior / coolant anti freeze / Fan / Ac fan / Water Pump is checked & free from trouble .
Advise me on wat could be the issue
Regards
Benny
Sep 21, 2006 at 4:19 AM
NOS
  • 320 POSTS
change your thermostat(NOS) 8)
Sep 21, 2006 at 12:15 PM
BENNYTOM24
[quote:cc32821318="NOS"]change your thermostat(NOS) 8)[/quote:cc32821318]
Thermostat is changed & it works fine
Sep 22, 2006 at 3:31 AM
NOS
  • 320 POSTS
maybe a lower radiator hose sucking shut under heavy load like pulling a hill. AC always puts more load on engine have you washed the coolng fins out in front of condensor and reverse washed back through the radiator side. could be a slite leaking headgasket problem puting compression back in the cooling system (NOS) 8)
Sep 22, 2006 at 12:42 PM
BUBBA_KOSKI
  • 129 POSTS
head gasket, radiator partially plugged, hoses, and not enough flow
Sep 28, 2006 at 3:45 PM
