no power at all
SEOKID
hi, my sister owns a 2000 ford escort w/ close to 100,000 miles. the problem is that at the current moment the car doesn't run after having sat for a week. there is no power at all. the car wont turn over and there is no power at all in the cabin. we have bought a new battery thinking that the other one could be dead, but that hasn't helped. could this be a fuse or ground wire?
Aug 12, 2007 at 10:18 AM
  • 75,988 POSTS
[quote:fdc6942b16="seokid"]hi, my sister owns a 2000 ford escort w/ close to 100,000 miles. the problem is that at the current moment the car doesn't run after having sat for a week. there is no power at all. the car wont turn over and there is no power at all in the cabin. we have bought a new battery thinking that the other one could be dead, but that hasn't helped. could this be a fuse or ground wire?[/quote:fdc6942b16]
You need to check all your fusible links some of them could be in the power distribution box and starter relay, and also could be at the starter-it has to go thru the links before it goes inside the cabin.
Dec 14, 2018 at 1:42 AM
