no power
MJRUTOWSKI
1996 ford escort 1.9 L mileage 91,000. Engine runs fine when cold, as soon as it get to normal operating temp, loses power and sluggish when starting from a stopped position. Already replaced EGR solenoid, EGR working fine , replaced front oxygen sensor, replaced catalytic converter cause it was glowing red. None of the thing solved anything and converter still glows red. No codes showing up either. Also getting extremely bad gas milage used to get about 300 miles per tank now getting about 150.
Mar 3, 2007 at 3:51 AM
CHEVY22
  • 1,375 POSTS
sounds like raw fuel is running down the exhaust , have you ever looked at the plugs and wires , start simple
thanks
if you are happy with the info please leave feedback we all here do this for free feedback is a way of saying thank you for the help
Mar 3, 2007 at 5:28 AM
MJRUTOWSKI
Plugs look perfect, changed plugs and wires 6 months ago.
Mar 3, 2007 at 6:01 AM
CHEVY22
  • 1,375 POSTS
the only other thing i can think is the injector is dumping fuel
Mar 3, 2007 at 7:12 AM
2CARPRO JACK
  • 11,533 POSTS
Fuel pressure regulator?
Mar 3, 2007 at 11:48 PM
CHEVY22
  • 1,375 POSTS
[quote:fdc274fe2f="2CarPro Jack"]Fuel pressure regulator?[/quote:fdc274fe2f]
yeah i wasnt thinking , up late
Mar 4, 2007 at 1:14 AM
