i have a 94 ford escort two door hatchback lx...and one day i sent to drive it..and it started up normally and idled normally nothing to make me think something is wrong.didn't even make it to the end of the block before it stalled..it started back up no problem and died before i could turn around to get home and would not start back up for several day and when it did it sounded normal idle speed was normal started up easily i was even able to put it into gear and move it around a little with no trouble but when i tried to drive it once again it died and since then it wont start..
it wouldn't even fire up..
since then i've changed the spark plugs, the plug wires, the pressure regulator, the fuel pump, and the mass air flow sensor.
and i'm pretty much lost for what to do next..
right now i can get it to start but only for a few seconds before it stalls out and when it does start the rpms are no lower then 1500..
any ideas would be greatly appreciated..
Jun 6, 2007 at 1:17 PM
