1995 Ford Escort Starts Then Dies
WYNRYPEN
  • 52 POSTS
1195 ford escort lx 1.9L with 180,000
i got the car firing up, then it shuts off, its sounding as if its getting gas, then something is blocking the gas to keep the car running. what to do now?
Jan 11, 2007 at 6:38 AM
BRUCE HUNT
  • 3,754 POSTS
Don't rule out that it could be an electrical issue that stops the engine. But let's pursue the fuel angle.
Have you replaced the fuel filter in a while? The pump could be weak and I would suggest a fuel pressure check. After that is the fuel pressure regulator.
When it stops does it start right away again?
Jan 11, 2007 at 7:03 AM
WYNRYPEN
  • 52 POSTS
it does, after a turn or two, but i got the thing firing up....
when it starts, and as i press on the gas pedal to keep it running, i get no response, i can rev it once, but thats it, and when i do get to rev it, when i put it to the floor, it revs high, high high, then it goes eeeerrrrrrrrr dies. i dunno if i just made sence or not, but, why is it doing that?
Jan 11, 2007 at 4:00 PM
WYNRYPEN
  • 52 POSTS
oh yea, new pump, new filter, im going to get a pressure regulator tommorow at pick n pull
Jan 11, 2007 at 4:01 PM
Suggested Repair
Check fuel pressure, then inspect or replace the fuel pressure regulator if pressure is incorrect. Do not rule out an electrical fault that cuts the engine. The fuel pump and filter were already replaced.
Conversation Summary
A 1995 Ford Escort LX 1.9L starts, then stalls. It sounds like it is getting fuel briefly, but throttle input gives little response; it may rev once very high and then die. It will restart after a turn or two. The owner reported a new fuel pump and filter and planned to get a pressure regulator. The expert advised not ruling out an electrical cutoff, and suggested checking the fuel filter, testing fuel pressure for a weak pump, and then checking the fuel pressure regulator.
