1988 Ford Escort No Spark
BARRETTBEE
I am a visitor to florida where I have a 1988 escort station Wagon, fuel injection 66,000 miles. Just before leaving the engine died on me as I was cruising at 50 along the highway. No juddering, coughing etc it just died and although I was in gear (automatic) the tacho dropped to zero as I drifted to a halt. The only other diagnostic I have tried is that when I turn the car over there is no spark from the coil. I do not have a manual at present so not sure which wires are which. Whats the most likely problem : fuses, ignition control box (where is it?!) etc any advice. Thanx keith
Dec 4, 2006 at 12:25 AM
CATCH_15
  • 250 POSTS
If you have no spark at the coil, it is either a bad coil, ignition module, or pick up coil.
Dec 4, 2006 at 2:52 AM
BARRETTBEE
Thank you for that advice, I'm a "contact breaker" era, how do you test the pick up coil?,
keith
Dec 5, 2006 at 10:32 PM
Suggested Repair
With no spark at the coil, check the ignition coil, ignition module, and pickup coil.
Conversation Summary
A 1988 Ford Escort station wagon died while cruising, and the owner found no spark from the coil. The expert said the likely causes are a bad coil, ignition module, or pickup coil. The owner asked how to test the pickup coil, but no test procedure was given.
