1992 Ford Escort No Spark No Start
Suggested Repair
Ground a spark plug while cranking to confirm there is no spark. With the key on, listen at the fuel tank for pump prime. If the pump may be seized, a careful rubber-mallet tap at the tank center while cranking may free it temporarily; replace the fuel pump if that restores operation. Also verify that the ignition control module was actually the part replaced.
Conversation Summary
The owner of a 1992 Ford Escort GT reported a sudden no-start with no spark after replacing the battery, coil, and parts believed to be the rotor and ignition control module. They later realized the used module was the wrong part and also noted no fuel smell. The expert advised grounding a plug to check spark, listening at the tank for fuel-pump prime, and tapping the tank to free a seized pump, followed by pump replacement if that works.
