ENGINEE CRANK NORMAL.
NO SPARK
Fuel pump ok. (hearing noise when turner on ign. key and test psi)
Code reader used and no fault codes, except for the pass test 111)
Fuses Ok. (Both blocks int. and ext.)
ECM relays OK.
Timing belt spin (Just uncover part of the plastic cover and look trhu the gap)
PARTS REPLACED.
1.Coil Pack.
2.-Ignition module
3.-ECM
4.-Crankshaft sensor.
5.-ECM Relay
Still have not spark on the spark plug wires and not spark on tap of coil.
Please help me because I tired of read the Chilton manual and looking for possible cause.
Sincerely
Jose
