1995 Ford Escort Hesitation
JCLAY5
I have a 1995 Ford escort with over 175,000.00 miles. We have replaced the timing belt, cam sensor, and we are still having problems with our car. When you step on the gas it is like something is missing it hesitates. When you are driving and take off from a light or want to speed up it hesitates like it is going to stall. When we are driving on the freeway at a speed of 65-70 miles sometimes it starts to hesitate and want to die. I have been going to a repair shop for 6months + for this problem everytime they fix it they say problem solved it running great but then we drive off and we still have the same problem.
Jan 30, 2007 at 1:10 PM
KNIGHTRIDERKITT2000
  • 93 POSTS
try replacing the fuel filter, check spark plugs and wires, and check for proper fuel pressure.
Jan 30, 2007 at 11:54 PM
  • 75,988 POSTS
Or check the TPS and Map sensors-Got OBD2 codes
Jan 31, 2007 at 7:51 AM
Suggested Repair
Scan for OBD2 codes, then check the TPS and MAP sensors. Also inspect the fuel filter, spark plugs and wires, and verify proper fuel pressure.
Conversation Summary
A 1995 Ford Escort with over 175,000 miles hesitates under acceleration, when pulling away, and at 65-70 mph, sometimes feeling like it will stall. The timing belt and cam sensor were already replaced, and repeated shop repairs did not solve it. Suggestions were to scan for OBD2 codes, check the TPS and MAP sensors, and also inspect the fuel filter, spark plugs, wires, and fuel pressure.
