My car died on me while driving last week.It acted as if it were running out of gas,so i got gas and it still wouldnt start.So, then i checked the fuel pump fuse(20-amp)under the hood and it was blown,so i replaced it with a 30-amp because that was all i had and it started.I then drove 15-miles and it started to cut-out again and blew that fuse too.We replaced the fuse and it woulnt start again.We pulled out the back seat and noticed the wiring clip to the fuel pump was burnt.I tested the fuel relay and fuel pump and are both good.Its just not getting power to the fuel pump when i turn on the key.the shutoff switch is also been reset and still doesnt start.
Nov 9, 2008 at 3:20 AM
