The rear end makes a horrible noise sounds like a flat tire what could this be
Oct 19, 2007 at 6:04 AM
Check the rear tires for separation. Safely lift and support the rear of the car, spin each rear tire, and watch for obvious tire damage or irregular movement.
The owner of a 2000 Ford Escort ZX2 reported a horrible rear-end noise that sounded like a flat tire. The expert suggested a separating rear tire and advised lifting and supporting the rear, then spinning the tires so any problem would be obvious by watching them.
