2000 Ford Escort 4 cyl Front Wheel Drive 11000 miles
HOW DO YOU CHANGE THE SIGNAL LIGHT BULBS
Oct 31, 2008 at 2:16 AM
BLUELIGHTNIN6
✓Experienced Mechanic
Front or rear? Pop trunk and look for the bolts holding the tail light assembly in. Remove this and access to the bulb should be easy. For the front, pop hood and see if you can gain access without removing headlights. Should be in your repair manual if you have one.
Oct 31, 2008 at 4:44 PM
