Car quits
HMAC300
  • 48,601 POSTS
Probably not but you are lucky with a blown fuse that car started. Replace fuse then scan for codes and check fuel pressure with a gauge auto parts rent it.
Saturday, August 18th, 2018 AT 12:56 PM (Merged)
DROBIN
No. It didn't start. That is how it acted. Before it died. I thought it was the battery, but it wasn't. Changed battery. Still no start, then I saw the fuse.
DROBIN
And thank you for the advice
JAYBEN
  • 2000 FORD ESCORT
  • 148 MILES
I just replaced the alternator, but now it idles really rough and dies when I come to a stop. What could be the problem?
JAYBEN
That's 148000 miles by the way.
Saturday, August 18th, 2018 AT 12:57 PM (Merged)
HMAC300
  • 48,601 POSTS
Make sure the battery is charged and recheck the alternator to make sure it is puttong voltage out.
GIRL_DANI
  • 2000 FORD ESCORT
  • 4 CYL
  • 77,800 MILES
My 2000 Escort has been idling really rough. When you come to a stop light, if you dont put it in part it will stall. I have replace the vacuum lines, spark plugs & wires, & serpentine belt. Been told it could many things. Any ideas?
Clean out the idle air control valve and EGR valve and test the TPS and MAF sensors-
