1998 Ford Escort transmission or clutch problem
DONALDP43140
  • 1998 FORD ESCORT
  • 4 CYL
  • MANUAL
  • 120,000 MILES
My Escort is locked up in 4th gear. I assumed that the clutch was bad. A mechanic told me if it will not shift and stays in 4th gear that the transmission is bad. What do you think?
Friday, February 13th, 2009 AT 11:56 PM
PEAR69
  • 1,482 POSTS
With the engine off -- rock or push the car so it rocks and try to put the tranny in neutral without pressing the clutch. You should be able to do this easily. If not then it is the transmission.
Saturday, February 14th, 2009 AT 12:05 AM
