1998 Ford Escort CLutch
SIGMOND29
  • 1998 FORD ESCORT
  • 4 CYL
  • FWD
  • MANUAL
  • 202,000 MILES
When the clutch is depressed I hear ratling in and when I stop in first or second it seems like the car is hesitating. I am thinking it is the clutch itself and is it a possible do it yourself job?
Sunday, May 16th, 2010 AT 11:16 AM
  • 109,885 POSTS
Can you describe the noise you hear? Does it sound like a bad bearing? Do you only hear it when the clutch is pushed.
Wednesday, May 26th, 2010 AT 8:20 AM
SIGMOND29
Yes only when the clutch is pushed. Otherwise it runs fine.
Wednesday, May 26th, 2010 AT 8:32 AM
  • 109,885 POSTS
I would have to say it is a throw out bearing that is bad. When you depress the clutch, the bearing engaged.
Wednesday, May 26th, 2010 AT 12:13 PM
