1998 Ford Escort No spark, now a buzzing noise out of compo
WALTHAM41
  • 1998 FORD ESCORT
Electrical problem
1998 Ford Escort 4 cyl Front Wheel Drive Automatic
98 Escort ZX2 sport
The car ran, was parked for 3 days, then cranked over fine but would not start. Put small amount of fuel in throttle body, no start, Diagnosed no spark to spark plugs. Replaced crankshaft sensor, still no spark and now upon reassembly from installing crankshaft sensor, a box under air filter housing with large wiring harness makes a squealing/buzzing noise when battery connected and key turned on. Pulling the 30A fuel inj fuse stops buzzing.
Car still cranks over fine but will not start and now have the buzzing from box under the round air filter housing.
engine is a 2.0L ZeTech
not sure what the box is, haynes manual does not show it. Suspect it is a control module of some sort.
Saturday, May 16th, 2009 AT 11:15 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 54,348 POSTS
Hi, it sound like a control relay has gone bad inside for the control module; do you have five volts to the any of the sensors? Like TPS? Also check the injector ohms reading to make sure none are shorted. If not you may have to replace the main control module under the air filter. and recheck all fuses. Please use this page for further reference.
https://www.2carpros.com/how_to/how_to_test_an_ignition_system.htm
please let me know how it goes,
Tuesday, May 19th, 2009 AT 12:36 PM
WALTHAM41
I changed out the main control module and the car is now running. Thank you for you help.
Friday, June 19th, 2009 AT 1:28 AM
