1998 Ford Escort COOLANT LIGHT
106,000 MILES • 4 CYL • FWD • AUTOMATIC
MTK2651
My check coolant light is always on,and my engine temp gauge never goes above (C) what is the likely problem.there is antifreeze is the radiator.
Dec 11, 2007 at 4:52 AM
BMRFIXIT
  • 19,053 POSTS
[quote:8c5724b350="mtk2651"]Other Category problem
1998 Ford Escort 4 cyl Front Wheel Drive Automatic 106000 miles
My check coolant light is always on,and my engine temp gauge never goes above (C) what is the likely problem.there is antifreeze is the radiator.[/quote:8c5724b350]
check the level sensor
temp @ C do you have heat
if not check or replace the thermostat
good luck
Dec 11, 2007 at 8:28 AM
