1998 Ford Escort Dash Lights Out
BILSONXNC
  • 11 POSTS
Ok i have a 1998 ford escort zx2 with 121000 miles on it its a 2 door .manual.
The kid i bought this car off of said that the dash lights stopped working when he put his cd player in? I checked all fuses and replaced the cluster its self.. the lights that light the buttons up on the heater dont work either.
Jul 31, 2007 at 3:15 PM
DSPLC
  • 220 POSTS
Regarding your dash lights, I think you cut one of the wire that gives power to your dash lights when you connected your CD player. Also, I have a 97 4DR Escort in which there is knob on the lower left side of the dashboard (with a picture like a small clock). If your park light switch is on, this knob is like a dimmer switch which brightens or turns off your dashboard /speedometer/ heater/aircon knob lights. If you turn the dimmer switch knob and still no lights, remove the knob housing and use a voltmeter to check if there is power from the wire.
Aug 2, 2007 at 5:50 PM
Suggested Repair
With the parking lights on, try the dash dimmer knob on the lower left of the dashboard. If the lights stay out, remove the knob housing and check that wire for power with a voltmeter. Also inspect the CD player wiring for a cut illumination feed to the cluster and heater controls.
Conversation Summary
A 1998 Ford Escort ZX2 lost dash and heater-control illumination after a CD player was installed. Fuses were checked and the instrument cluster was replaced without success. The expert suggested a cut illumination power wire from the stereo install and advised testing the dash dimmer switch and its wiring for power.
