1997 Ford Escort transmission won't engage even after it ru
99,999 MILES • 4 CYL • FWD • AUTOMATIC
KY_COWBOY41093
is there a sensor that needs to be replaced that makes it engage or shift? this has me baffled and it is getting to be a hasle. the transmission works fine sometimes and then it just won't engage or shift in any position.
May 11, 2009 at 2:16 PM
BMRFIXIT
  • 19,053 POSTS
Start engine , Check tranny fluid and adjust as needed
have to get tranny codes if any
if does not move in any selected position and tranny fluid is OK
I would suspect internal tranny failure
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
May 12, 2009 at 11:14 PM
