1997 Ford Escort Probably transmission
CECYLOVE4
  • 1997 FORD ESCORT
  • 4 CYL
  • 4WD
  • 134,000 MILES
While driver my car made a noise, like something broke. I pulled over and parked, when I changed the cludge to drive again my car wouldn't run at all. The engine will start buy it won't run neither on reverse nor drive mode. What can be problem? Is it the transmission?
Sunday, January 17th, 2010 AT 2:52 PM
BMRFIXIT
  • 19,053 POSTS
Check axles 1st
place it on flat ground
engine off place shifter gear in park if automatic or 1st if manual
exit car and try to push it if it dose move suspect axles
if not is tranny internal
Sunday, January 17th, 2010 AT 2:58 PM
