2000 Ford Escort No Reverse
153,000 MILES • 4 CYL • FWD • AUTOMATIC
RMILLE34
My car was purchased from an older lady. When i brought it home it ran fine for about 3 months. The acceleration became sluggish and after a bottle of Gumout that was fixed, but i became aware of an issue with my reverse. It doesn't go in reverse, or when it does it sounds like i'm driving a manual trans. with the clutch down. the engine just runs really high like i'm in neutral with the gas pedal down. Sometimes it moves, sometimes it doesn't.
I have no issues going forward so far.
The engine is a 2000, but the car itself is a 1998. The new engine was unknowingly dropped into it before we bought it.
I was shown a small arm inside the engine compartment that i was told i could manipulate and it'd adjust the reverse mechanism.
Is there anything inside the engine compartment like that?
If not, is this a fixable problem or will i have to replace the whole trans?
Jul 27, 2009 at 1:44 AM
BMRFIXIT
  • 19,053 POSTS
Tranny in need to be rebuilt
reverse clutch and low -low reverse clutch need to be checked and replaced
I dont know of any adjustment on your vehicle
is it the link between throttle and tranny and if so I don not believe that is going to help in your situation
good luck
Jul 27, 2009 at 11:15 PM
