Hi there,
I have had a look at the transmission on Mitchell 1, unfortunately this dose not show me what I was looking for, so all I can suggest is that you check the selector linkage for worn or damaged bushes, watch the action at the transmission when each gear is selected, it should be firm movement and a positive engagement, if there is any slack in the selectors this will have to be checked and repaired, otherwise the problem may be internal, but I would even get a mechanic to double check the selectors first.
Mark (mhpautos)
Thursday, September 24th, 2009 AT 5:17 AM
