1997 Ford Escort car cuts out
1997 FORD ESCORT
WERONA
Engine Performance problem
1997 Ford Escort Manual 97567 miles
hi there i have a 1997 ford escort 1.8 si, when driving the vehicle it cuts out in low gear such as coming to a junction but drives fine in higher gears also what is the best way to get to the oil filter so i can change the oil, and how do you set the tick over? hope you can help, many thanks
Dec 14, 2009 at 9:07 AM
NAZZNATE
  • 7 POSTS
I am only addressing your car shutting off - it could be a PCV valve, and i think your's is in the valve cover. I'm not a mechanic, but my car is doing the same thing. There is a label (sticker) under the hood that diagrams where the vacuum hoses are located, and that's how I found mine. I have a 1.9 L engine and mine is easily accessable, but yours is in a different place. Do an internet search on "checking escort pcv valve". That helped me tremendously.
Dec 15, 2009 at 12:15 AM
WERONA
thank you very much nazznate will certainly check that out, thanks for replying, merry xmas
Dec 16, 2009 at 1:39 PM
NAZZNATE
  • 7 POSTS
Good luck, Merry Christmas! Be Blessed!
Dec 16, 2009 at 11:39 PM
HAHNY1
  • 75 POSTS
ours would sometimes shutter, kinda felt like the tranny was slipping or like the car was sputtering, we fixed ours by changing the plug and wires
Feb 10, 2010 at 3:38 PM
