1994 Ford Escort Mileage 130,002
SOR05GA
Engine Performance problem
1994 Ford Escort 4 cyl Front Wheel Drive Automatic
Sometimes when starting car, it shutters and acts as if it might cut off (once or twice it did cut off). We had the spark plugs, oil and oil filter changed. Also, check the vacuum hose and carburetor for possible problems and found none. Is it possible the gas being used?
Jun 16, 2008 at 4:31 AM
BMRFIXIT
  • 19,053 POSTS
I would check the rest of the tune and fuel filter too
also check and clean idle air control
Have an automotive repair question!
Sign up and ask your automotive question !
https://www.2carpros.com/affiliate/uid/bmrfixit_1_tlid_1
Jun 16, 2008 at 11:55 AM
