1996 Ford Escort strutts
SUPERJOKER
  • 1996 FORD ESCORT
Suspension problem
1996 Ford Escort 4 cyl Front Wheel Drive Manual
i need to replace the strutts in a 1996 ford escort wagon. What kind of tools and such do I need to do the job
Saturday, October 17th, 2009 AT 11:13 AM
  • 109,896 POSTS
THe necessary tools are straight forward. However, you will need a coil spring compressor. Most parts stores will lend or rent them to you.
Please be careful and follow the directions that come with the tool. A coil spring could kill you if it gets loose and hits you.
Also, the vehicle should be aligned after the job is done.
Monday, October 19th, 2009 AT 9:18 PM
