1998 Ford Escort broken bolts
CNTDSC
Tires and Wheels problem
1998 Ford Escort 4 cyl Front Wheel Drive Automatic
i broke two bolts on my front tirer trying to put my winter tirers on. how do i replace them?
Nov 30, 2008 at 2:16 AM
RICK 08
  • 54 POSTS
Hi: I am not a pro mechanic nor am I up to date on this assembly, for what it is worth. .
Try calling some part stores, at one time thay did sell replacement bolts that used a insert assy.
This required punching out existing bolts that are pressed in. Again if you have not alredy done so check with the parts stores & see what advise and kits thay may have.
Dec 3, 2008 at 4:20 PM
