1995 Ford Escort the car stop running when I wait on a red
ALAINBERGERON
  • 1995 FORD ESCORT
  • 4 CYL
  • 99,000 MILES
Can you tell me what to do for ajusting the idle engine.
Thank You very much
Friday, September 24th, 2010 AT 12:21 PM
WRENCHTECH
  • 20,761 POSTS
The idle speed is not adjustable at all. It is completely computer controlled.
You may have a bad IAC ( idle air control) but try cleaning the throttle body first. Remove the intake snorkel, have someone hold the throttle wide open for you and scrub the back side of the throttle plate and surrounding bore with an old tooth brush and some carb cleaner. Be sure to spray some into the small holes next to the throttle plate. That should help stabilize the idle. If it still has a problem, replace the IAC.
Friday, September 24th, 2010 AT 1:00 PM
