1995 Ford Escort Heater Core
KENRINGERING
  • 1995 FORD ESCORT
Heater problem
1995 Ford Escort 4 cyl Front Wheel Drive Manual
I am having trouble removing the heater how can it be removed Does the blower unit need to be removed as well?
Sunday, November 9th, 2008 AT 5:52 PM
BMRFIXIT
  • 19,053 POSTS
HEATER CORE
Removal & Installation
1.Disconnect negative battery cable. Drain cooling system. Disconnect heater hoses from heater core, and plug openings. Detach hood release cable. Remove both dash side panels. Remove left and right lower dash trim panels. Remove glove box. Remove 7 screws securing center accessory console. Disconnect wires on accessory console, and remove accessory console. Remove control cables at heater case.
2.Remove 4 bolts securing steering column to instrument panel. Lower steering column. Remove 2 bolts from instrument panel mounts at far left and right sides of instrument panel. Remove defroster duct trim on top of dash. Remove instrument cluster screws. Pull instrument cluster out slightly. Disconnect electrical connections and speedometer cable from instrument cluster. Remove instrument cluster.
3.Disconnect all electrical connectors from instrument panel. Remove parking brake console. Remove glove box. Remove bolts securing instrument panel support to floorpan. Remove all instrument panel mounting bolts. Remove instrument panel.
4.Separate heater case from blower. Remove 3 nuts and pull heater case from firewall. Remove heater core access cover, and pull heater core from heater case.
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic1_51.jpg
. To install, reverse removal procedure.
Sunday, November 9th, 2008 AT 6:54 PM
