It cranks thru when you jump the cooling fan power relay-test the NSS located on top of the transaxle check for power on the wiring connector one of the 2 should have power when key at starting position if not the ignition switch is no good if power is there and you jumper it and it cranks the engine over the NSS is defective.
SPONSORED LINKS
Friday, December 14th, 2018 AT 9:41 AM
