Will not turn over
19,000 MILES • 1.9L • 4 CYL • FWD • AUTOMATIC
DKRUBY94
When turn key everything engages but it will not turn over. It is not battery. It happened before kept juggling a lot of ignition and multi harness. also, shifting finally started did good for long time now started got to store turned off and here we are had to be towed home. Where do I start?
Jul 11, 2017 at 4:02 AM
  • 55,721 POSTS
It sounds like you might have a starter that has gone bad, Here is a guide to help you run a test to confirm.
https://www.2carpros.com/articles/car-engine-will-not-crank-over
Near the bottom of the guide it shows how to test the starter.
Please run this test and get back to us we are interested to see what it is.
Cheers, Ken
Dec 14, 2018 at 1:37 AM
