1994 Ford Escort car wont crank
RONALD56789
  • 1994 FORD ESCORT
Electrical problem
1994 Ford Escort 4 cyl Two Wheel Drive Automatic 156k miles
I turn key nothing happenes. I have a new battery, alternator and the starter was tested and works. For some reason I am not getting 12 volts to the starter to crank over. I tested the small wire that goes to the starter but I get very low volts to it,
I can start the car if I short the starter and it runs, but I cant start it with just the key.
Thoughts
Tuesday, March 10th, 2009 AT 7:27 PM
Check the starter relay, park and neutral switch, and ignition switch
Friday, December 14th, 2018 AT 9:38 AM
RONALD56789
Where is the starter relay in this car?
From the battery terminal of the starter follow the cable towards the battery you'll run right into it
