1994 Ford Escort transmission won't engage with engine runn
BCTAYL
  • 1994 FORD ESCORT
1994 Ford Escort Front Wheel Drive Manual 114000 miles
My grandson's Escort GT will not shift into gear with the engine running but goes in just fine with the engine idle. It's like you aren't even pushing the clutch pedal down. Could this have something to do with the clutch master cylinder? I haven't worked on a car since about 1988 when I replaced the timing chain on my son's 1980 T-Bird and thought this was all behind me until we wound up having to raise 3 of our grandchildren last year. Thanks for any help you can give me on this as we have limited funds and so does he.
Sunday, January 20th, 2008 AT 1:34 PM
MUSTANG87
  • 261 POSTS
Try bleeding it. See if its leaking any oil. Check clutch master cyl and slave cyl. If you dont know what they look like go to www. Kragen. Com and see the pics of the parts.
Monday, January 21st, 2008 AT 3:46 PM
