1994 Ford Escort Heating problem
109,800 MILES • 4 CYL • 2WD • MANUAL
SKULLY203
I replace the thermostat already. All hosed get hot, including the 2 for the heater core, but when I turn the fan on, the "out" hose from the heater core goes cold and the temp inside the car never gets hot. Is it the core or something else?
Jan 31, 2009 at 8:28 AM
  • 110,248 POSTS
If the return hose from the heater core gets cold, there is no coolant flowing through the heater core. Try removing the heater core hoses and flush the core to see if that helps.
Let me know if this helps.
Feb 1, 2009 at 11:17 AM
