1994 Ford Escort Cooling fans
116,000 MILES • 4 CYL • FWD • AUTOMATIC
RALDOG
I had a minor fender-bender the other day, and the OEM water pump began leaking. I had a mechanic replace the water pump, and now the cooling fans will not come on. They run for a few seconds when I turn it off, then turn the key back on, then they quit.
Is there a sensor or something that the mechanic did not reconnect?
Jan 13, 2009 at 7:02 AM
BMRFIXIT
  • 19,053 POSTS
They should come on only when needed (engine hot )
if you have working AC put the selector on defrost the coolant fan should cycle
check fuses and relay check wiring and motor
Jan 13, 2009 at 11:11 AM
