1995 Ford Escort Radiator Fan not coming on
PAT SCIB
  • 1995 FORD ESCORT
  • 4 CYL
  • MANUAL
  • 143,000 MILES
Radiator fan not coming on. Already changed fan motor, brokern thermostat, relay in fuse box under hood & associated fuses. Could it be a fuse link and where do I find them? Any help is appreciatred.
Monday, August 18th, 2008 AT 7:15 PM
BLACKOP555
  • 10,371 POSTS
There should be a fusible link, follow the battery cables to find um. Hard to miss, say fusible link right on um.
First thing to do is check the coolant temperature switch NOT the sending unit. From there take and put +12v to te signal wire, does it turn on? If not then the relay, wiring harness, or motor is bad. If it does turn on switch is bad, or its not getting voltage.
Monday, August 18th, 2008 AT 10:24 PM
